The user, Dell, sought help on a Windows 10 forum regarding activating a Mercedes workshop manual software using the correct Wi-Fi MAC address instead of the Ethernet MAC address, which was causing activation issues. A responder suggested contacting support or checking where the MAC address might be stored, but Dell later resolved the problem by resetting their router. The overall tone is one of troubleshooting and problem resolution.
Dell
Well-Known Member
Hi all
i am hoping someone can help me.
i have installed Mercedes EWA/epc/wis workshop manual / parts cat on my Windows 10,but I am having trouble running it and I have just found out that I have activated it with the wrong MAC address it is using Ethernet MAC address when it should be activated using the wifi MAC address as the Ethernet cable is not connected,but I don't know how to make the program use the wifi MAC address instead.
any help would be much appreciated thank in advance Dell
Neemobeer
Windows Forum Team
Have you tried contacting their support about how to change it? It could be stored in a file, registry or on the vendors end.
