kode
I have installed some updates to my win 7 pro. After restarting I try to rename, move, copy and so on, and in every action pops up a window with "Try again" and "cancel". The main title of the window is "Item not found". Then, there is "Could not find this item. This is no longer located in d:\...." bla bla bla.
When I click Try again action is executed(file is renamed, moved or copied... whatever I want to do)
The problem is that every time pops this annoying windows that says that something is not there where it is.
Any hints?
cybercore
If the system updates were the only change to your system, you may want to restore it to the state before the updates.
