Conduct
Banned
Hello Friends!!
I used Problem Step recorder to make a youtube video and it says Video >>Falied<<
My Question: Is Problem Step Recorder a good thing to use to make youtube videos?
I don't have any experience with the format either, but it seems you might be able to convert it to something like a power point presentation (or something similar) and then to a video. I do not know if there is any free software to do this or if Power Point can be made into a video directly.
zvit
Honorable Member
I don't use this but I read that The Problem Steps Recorder in the Windows 7 operating system is a feature that enables users to record their interactions with an application and provide a detailed screen-by-screen view with accompanying information. So I don't understand how you used it to make a video?
Elmer
Hi conduct. It's saved as an mht document with a series of images with the key presses listed above.
Saltgrass
