The thread discusses Johnston7's frustrations after upgrading to Windows 7, which removed Windows Mail and caused issues importing contacts into Thunderbird. Contributors suggest alternatives like Windows Live Mail and exporting contacts in compatible formats, with some advice on the new "Sync" feature replacing "Send and Receive." Overall, the tone reflects a mixture of troubleshooting efforts and the challenge of adapting to new email clients for novice users.
Johnston7
I regret upgrading to Windows 7. But too late now it seems, as I can't retore my computer to the previous OS.
So I'm stuck, and can't use Livemail. I have downloaded Thunderbird but can't import my contacts (address book).
Can anyone reccomend a simple email client to use, or advise how a novice like me can import my address book to Thunderbird.
I am about to set fire to the computer.
John
Saltgrass
I do not use any "Live" utilities, but I thought Live Mail was the default option with Win 7..
kbz1960
Import from what mail program to Thunderbird?
W7 comes w/no mail program at all, they suggest that you get their "live essentials" for mail, IM etc. that isn't included.
Johnston7
Thread Author #5
My contacts were in Windows Mail when operating Vista, then I 'upgraded' to Windows 7. They're still on the computer. But after downloading Thunderbird I can't import the address book.
John
tblount
Why don't you run Windows Live email ? It's basically outlook express with some graphics changes.
I think all contacts have .contacts as the file extension you do know to search?
kbz1960
Did you export your contacts from windows mail, if so in what format? .CSV (comma seperated values) is the one most email programs will read.
Johnston7
Thread Author #8
tblount:
Livemail doesn't appear to have a 'send and receive' button, and I have to log off and get the 'you have unsent messages......do you want to send now' message. Why they change something that is perfectly OK (Outlook Express or even Windows Mail) I don't know.
kbz1960:
I didn't export contacts from Vista to 7, it just did it during upgrade.
Bear in mind I am a novice.
P.S. if the '1960' refers to your birth year you'll be the big five-ohhh like me next year.
john
Johnston7
Thread Author #10
Rak.
Thanks for that, I'll try that when I get home the weekend.
Do you use livemail and if so is it user friendly?. It may be my objection to change clouding my judgement.
John
ickymay
i use livemail for my hotmail accounts and incredimail for my pop3 email, all working well :)
Johnston7
Thread Author #12
Thanks guys. I'll try livemail.
One annoyance with 7 is that the explorer window keeps appearing at start up and I can't stop it. Any clues how to.
John
tblount
tblount:
john
My age is posted with ever message. I was born in 51... i think someone else has 1960 in their nick or something.
