Jacob Clegg
OK, so I get the Start Windows normally or Repair screen, then I get the insert disk and restart, then choose your language settings. Then it tries to repair my computer, then it says no problem found or something like that. Then I get the details
Problem Event Name : StartupRepairOffline
Problem Signature 1 : 6.1.7600.16385
PS 2: 6.1.7600.16385
PS 3: Unknown
PS 4: 21200055
PS 5: ExternalMedia
PS 6: 6
PS 7: NoRootCause
OS Version : 6.1.7600.2.0.0.256.1
Locale ID: 1033
Your description is a little short for us to understand what is happening. Sometimes telling the whole story helps put the events in perspective.
Your system was running fine until _______ ?
If you select repair does it go into the Windows Repair Environment, or do you have to boot to the Install DVD?
I have not seen such a message before, but it appears you are running without SP1, so is this a new install?
Saltgrass
