The original poster is experiencing persistent errors when attempting to install specific Windows updates and wants to prevent these updates from installing. A responder explains that Windows 10 automatically installs updates regardless of user preference but suggests running the Windows Update Troubleshooter as a possible solution. Overall, the discussion centers on update issues and the inability to easily block problematic updates.
Curious
Helo,
Installing update KB3124266 i get the error 0x80246013 and with update KB2267602 i get the error 0x80070643.
The very big problem with these updates, is that, they are permanently trying to install and giving always the error and after this rebooting the system.
How i can say to Windows that i don´t want to install these upadates?
Thank you
MinecraftKid45
Well-Known Member
You can't,Microsoft made Windows 10, so that it installs updates no matter what!
Try running the Windows Update Troubleshooter
