The thread discusses troubleshooting a 2015 Alienware X51 with a blank screen despite functioning hardware and correct cable connections. The original poster emphasizes difficulty diagnosing the issue due to the monitor remaining blank and being unable to install drivers or test with additional monitors. Subsequent replies clarify assumptions about testing with multiple monitors and the importance of verifying hardware components, with the overall tone being collaborative and focused on identifying the hardware problem.
SavorySilicon
Hello, I have an old Alienware, it could be Model X51, and it is from approximately 2015. a small skinny desktop shape. It turns on, with very loud fans, but I have pluged almost all video cables into it, and the screen is blank. The screen is always blank, the screen has always been completely blank, it does not work at all. I am using a well tested perfectly working monitor. I have tried both the GPU's HDMI & DVI, and also the onboard HDMI directly on the motherboard, but neither one displays anything. I have checked all cables are plugged in correctly. What are the next troubleshooting steps I should take? Thanks guys.
SavorySilicon
Thread Author #3
Please check if the latest drivers (especially the graphics card) are installed on your computer:
Don't forget to restart the computer after installing new drivers.
Can you please re-read what I said in my post. I really don't think you read it.
SavorySilicon
Thread Author #5
You haven't mentioned anything about drivers.
Please correct me if I am wrong.
Thats right, I didn't. I also said the PC always has a blank screen, no matter what buttons I push, or what known good monitor and known good cable I connect it to. That means I can't install drivers or anything else onto the computer. No need to state the obvious about restarting either.
livix07
Honorable Member
Sorry, my bad. Somehow I assumed you had more than 1 monitor and just wanted to test this one.
Normally you need another monitor in order to test if the computer works. Otherwise how to check whether the monitor is defective or the graphics card on the computer or something else.
SavorySilicon
Thread Author #7
It's ok, mistakes happen. Yea I am using the monitor to type this on the screen heh from a different comp. If I figure out what is going on with this dead alienware I will let everyone know.
