hi all first of all sorry if its the wrong place i have been doing some work on my second pc a packard bell imedia a5518uk well today the screen went off and the no signal message came up thought maybe it went off as i not moved the mouse for a bit so i moved the mouse and the wireless transmitter that flashes green when i use the keyboard and mouse did not flash so i tried the keyboard thinking maybe a bit more to it did not work by now i thought maybe it has froze so held the button for a force shutdown it would not turn off so had to unplug then when i plugged it back in the power light will not light up but i can hear and see the fans spinning around
The forum thread discusses a PC that experienced a no-signal display and power issues, with the original poster describing troubleshooting steps including force shutdowns and checking the power supply. After some investigation, it was identified that the problem was caused by a faulty power supply unit (PSU). The overall sentiment suggests replacing the PSU as the solution, and advice is given to consider warranty options if applicable.
