The user reports that their webcam flickers after 30-60 seconds during Zoom calls, even when using an external webcam. A responder suggests testing the webcam with other applications like the built-in camera app and ensuring Zoom is using the correct camera, advising reinstallation of Zoom if the problem persists. Overall, the discussion focuses on troubleshooting webcam flickering issues with potential solutions including testing and reinstallation.
ianmich
An image from 'Webcam issue'. Split-screen showing a distorted video call with a man's clear face at the bottom.
I have been having issues using my webcam on Zoom. It works at first for 30 to 60 seconds then it starts flickering as shown in the picture. I tried buying an external webcam but it still has same issue.
Have you tested a different application like the built-in camera app? Did you validate that Zoom was using the new camera in your tests?
If the issue is solely with Zoom then remove and re-install would be advised.
Neemobeer
Windows Forum Team
