Tigercub
I have a problem with my system and websites. For instance, I typed in the title above and clicked on the box to the right, to check if it had already posted...all I get is the time circle, it never loads.
This happens to most sites I visit. I also get the problem when I search for sites and the list is displayed, then if I click on the site I require it does not load, just the timer runs. I can get into my home page. It seems as if it stops me going to a sub page or downloading files. I did have the error or message operation terminated due to settings on your computer. I went through the list of default programs and that message no longer appears but I am still not able to download or view webpages.
It was ok but for some reason the gremlins have entered my system and all is not well now.
Has anyone had this trouble and how can I fix it please. Your support would be very much appreciated. :(
It sounds like you are experiencing issues with loading websites and accessing certain pages on your system. This could be due to various reasons such as browser settings, network issues, or even malware. Here are some steps you can take to troubleshoot and hopefully resolve the issue: 1. Clear Browser Cache and Cookies: - Clearing the cache and cookies in your browser can often resolve loading issues. This will remove stored data that could be causing conflicts. 2. Check Internet Connection: - Ensure that your internet connection is stable. Try accessing websites from different devices to see if the issue persists. 3. Disable Browser Extensions: - Some browser extensions could be causing conflicts. Try disabling all...
It sounds like you are experiencing issues with loading websites and accessing certain pages on your system. This could be due to various reasons such as browser settings, network issues, or even malware. Here are some steps you can take to troubleshoot and hopefully resolve the issue: 1. Clear Browser Cache and Cookies: - Clearing the cache and cookies in your browser can often resolve loading issues. This will remove stored data that could be causing conflicts. 2. Check Internet Connection: - Ensure that your internet connection is stable. Try accessing websites from different devices to see if the issue persists. 3. Disable Browser Extensions: - Some browser extensions could be causing conflicts. Try disabling all extensions and then enabling them one by one to identify the problematic one. 4. Run Antivirus Scan: - Perform a full system scan with your antivirus software to check for any malware or viruses that could be affecting your browsing experience. 5. Reset Browser Settings: - Resetting your browser settings to default can help eliminate any custom settings that might be causing the issue. 6. Check Firewall and Security Settings: - Ensure that your firewall and security settings are not overly restrictive, blocking access to certain websites. 7. Update Browser and Operating System: - Make sure your browser and operating system are up to date. Sometimes, updates can fix compatibility issues. 8. DNS Settings: - Try changing your DNS settings to a public DNS like Google DNS (8.8.8.8, 8.8.4.4) or Cloudflare DNS (1.1.1.1) to see if it improves website loading speeds. 9. System Restore: - As a last resort, you can consider performing a system restore to a point where your system was functioning normally. If you've tried these steps and are still facing issues, it might be worth seeking professional IT support to diagnose and fix the problem. Hopefully, these tips help you get your system back to working order.
