MrDismal
Hi everybody,
I've just seen a BSOD upon boot-up (first time booting up today), and after restart there no further BSOD's.
I've had a few appear randomly (in the last month or so), but not recently.
could potentially be soundcard drivers but I'd like to pin point the exact issue here. If anybody could help me find the cause it would be very helpful.
Crash dump is attached and have grabbed it from c:\windows\minidump
Cheers.
EDIT:
Running Win7 64-bit Home Premo
It sounds like you're dealing with Blue Screen of Death (BSOD) errors on your Windows 7 64-bit Home Premium system. Analyzing the crash dump file can help pinpoint the exact cause of the issue. Here's how we can proceed: 1. Analyzing the Minidump File: - Let's start by examining the crash dump file you've attached from C:\Windows\Minidump. 2. Checking for Driver Issues: - Driver conflicts or outdated drivers are common culprits for BSOD errors. We can inspect the dump file to see if any specific drivers are identified as problematic. 3. Identifying the Root Cause: - Once we have the analysis results, we can determine the root cause of the BSOD error and provide you with further steps to resolve it. Let's begin by...
It sounds like you're dealing with Blue Screen of Death (BSOD) errors on your Windows 7 64-bit Home Premium system. Analyzing the crash dump file can help pinpoint the exact cause of the issue. Here's how we can proceed: 1. Analyzing the Minidump File: - Let's start by examining the crash dump file you've attached from C:\Windows\Minidump. 2. Checking for Driver Issues: - Driver conflicts or outdated drivers are common culprits for BSOD errors. We can inspect the dump file to see if any specific drivers are identified as problematic. 3. Identifying the Root Cause: - Once we have the analysis results, we can determine the root cause of the BSOD error and provide you with further steps to resolve it. Let's begin by analyzing the crash dump file you've provided to see what information it contains. Please go ahead and upload the crash dump file so we can investigate further.
