The thread discusses issues related to disconnecting an external hard drive used for an iTunes library, with the original poster experiencing difficulties due to a program accessing the drive after closing iTunes. Several suggestions include consolidating iTunes files on the same drive, uninstalling and reinstalling iTunes, and safely shutting down the computer before disconnecting the external drive. Ultimately, the user resolved the problem by moving everything to a different internal drive and reinstalling iTunes, expressing gratitude for the community's assistance.
Terry Day
I am expereincing a problem I am not sure it's a Windows issue or I Tunes. I store my Tunes Library on a seperate External Hard Drive as the file size is quite big 1786 Song Tracks. When I have finished using I Tunes to play any music and shut I Tunes down my Exteranl hard Drive will not close down and I am receiving a message 'USB generic device - another programme is accessing this and cannot close down' or words to that effect. I am unable to identify the programme in question and I have looked in Services to see what is running and cannot determine the fault. Aplogise if this is not a Windows 7 related issue, any help would be greatly appreciated
This is what I would do.....I would use Revo Uninstaller and uninstall iTunes. Once that is done, the do the advanced scan to find all the left overs, then delete those. Then reboot.
Then download a new copy of iTunes and install it on the C or D drive.......keeping it's entire contents on either drive.
Jimbo22
I'm pretty sure the issue is you have itunes installed on C drive and your iTunes library on the external HDD. You need to put them on the same drive....ideally on the C drive.
Rapaaja
Active Member
D Therefore, make them a common file / or your own D file, which you can move more easily.
In the end where do you want to save / use
I love it because C Drive is a machine-related partition not for storage.
Rapaaja
Active Member
If there is any functional tease on your device please let us know?
AND you want to miss yes understanding hidden / choice
Terry Day
Thread Author #6
HI Terry
Assuming music
I suggest you make a file about them
They are in a File in my External Drive the problem is the drive won't release as there is another programme using it??
Jimbo22
Terost
Well-Known Member
I keep my music files on my external hard drive. Most of the time, the computer sees the external hard drive as another drive to the computer and l am unable to eject the hard drive. What l do is shut down the computer completely and l unplug the external drive. The shut down will close all programs running.
Sent from my LGMS631 using Tapatalk
Terry Day
Thread Author #10
I have moved everything to another Hard Drive in my tower and re -installed I Tunes. All well now thanks for all your comments and advice.
Rapaaja
Active Member
TEROST thanks
