migs7792
I accidentally checked the 'Read-only' attribute for one of the folders under 'Users' inside the C drive. I am not sure if this is the cause but here are the following symptoms.
1. I cannot even click the taskbar icons such as 'Start', 'Search' and others.
2. I cannot right-click any folder and file, and when I do there is loading icon that never stops then the window closes down.
3. When I hover the taskbar, it's stuck with a loading icon.
4. When I open the Task Manager, it's also stuck in a loading state.
5. All the programs pinned at the taskbar disappeared.
6. Nothing happens when I do the combo 'Windows key' + 'R' because I was supposed to run PowerShell.
I can open the Command Prompt and Control Panel using the 'Windows key' + 'X' combination. I tried the 'sfc/scannow' command twice but it says "Windows Resource Protection did not find any integrity violations". I don't know what this means.
Please help. Thanks for reading.
Perhaps this helps:
- open the command prompt
- in the command prompt type CD.. than type DIR
You should see something like
Directory of C:\Users
03-05-2017 22:19 <DIR> .
03-05-2017 22:19 <DIR> ..
03-05-2017 22:21 <DIR> Default.migrated
14-03-2017 19:03 <DIR> defaultuser0
05-05-2017 16:55 <DIR> your_name
10-05-2017 15:54 <DIR> Public
0 File(s) 0 bytes
7 Dir(s) 189.134.249.984 bytes free
Than type
ATTRIB -R your_name
This should clear the read-only attribute
I will keep my fingers crossed
bochane
Perhaps this helps:
0 File(s) 0 bytes
Than type
ATTRIB -R your_name
migs7792
Perhaps this helps:
- in the command prompt type cd.. than dir
0 File(s) 0 bytes
Than try
ATTRIB -R your_name
I tried this one and I can't find the bolded folder name in the command prompt. Only Public and defaultuser0. However when I open the file explorer, the folder is there.
davehc
One of the user folders under 'Users'.
? there are very few there. Normally, you would see
username
Default
Public
If you are able to recall, select the properties again and see if you have "hidden" it.
bochane
What is listed with DIR in the directory C:\Users?
If there is some other user directory, then type ATTRIB other-name (sustitute other-name with the listed name)
If the ATTRIB listing shows an attribute (I expect R = read-only) than clear it with the -R option (use ATTRIB /? for help).
As Dave says, you may also find the attribute H (= hidden file), clear it with the -H option.
archola81
If your on creators update, you can do fresh restart. Theres option in windows defender, it tooks just half our, and keeps your personal files, pictures, documents etc...Of course, it gone delete some aplication instaled by you, but its nothing bad, you can install it later, but you will have your windows 10 fresh like new, with creators update of course...[emoji4][emoji4][emoji4]
Sent from my HUAWEI NXT-L29 using Tapatalk
