If chkdsk isn't working it's the problem then. Your system files may be corrupted, you can check them with sfc /scannow. Have you tried fixing the winload.exe error with these commands typed in the commands prompt window:
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /fixmbr
reghakr
- Joined
- Jan 26, 2009
- Messages
- 14,185
Hello and welcome to the Windows7forums,
Do you have an actual purchased copy of Windows 7?
or does it reside on a a recovery partition on your hard drive?
Did you make DVD backups when you first received the computer.
Is the computer under warranty?
- Thread Author
- #3
Thank you!
Yes I have an actual copy of windows 7 but I don't have it it's at home and yes I have 1 year warranty but I thought maybe I can do something or download something so the problem will be fixed?
Yours,
Kratos
Yours,
Kratos
- Joined
- Oct 16, 2009
- Messages
- 15,152
I don't know what Dell DataSafe is, but my laptop came with the recovery partiton. You can use an F key during boot to get to the recovery utility. I do not remember which F key, maybe F8. This will put your machine back to the factory install, if you have this system.
Check your owner's manual or the Dell Site.
reghakr
- Joined
- Jan 26, 2009
- Messages
- 14,185
Hello Kratos,
I would make one toll-free phone call to tech support. Maybe it's something they've run across in the past.
When you realize the person doesn't know how to operate a computer, say Thank you and hang up.
Then come here for a real solution.
Was Windows 7 pre-installed on the PC?
Maybe a good cleaning of the DVD with a very soft cloth would help.
Feel free to post back.
- Thread Author
- #6
Thanks for the replies. Yes it was preinstalled. It came with a CD but that aint very useful cuz I have no CD Drive.
Dell Datasafe is a recovery program that let me recover my laptop back to the factory settings.
I've used it once and it worked fine and now I want to use it again but I can't cuz of winload.exe
Delldatasafe is the only recovery I have (At least what I am aware of)
Is there ANYTHING I can download to fix this problem? I need something like a Boot Fix.
- Thread Author
- #8
Well one of them is that when I start up my computer it tells me that it needs to check the hard drive, I can cancel it within 9 seconds by pressing any button but if I don't it just does nothing. No checking at all. I just want a computer without errors
cybercore
- Joined
- Jul 7, 2009
- Messages
- 15,612
Hi and Welcome,
on the boot error "winload.exe", in the command line, type chkdsk /r /f and wait for the operation to complete. It is supposed to scan your hdd and fix errors. You should've created a system image backup, plenty of freeware solutions:
Clonezilla
DriveImage XML Backup Software - Data Recovery Product
Clonezilla
- Thread Author
- #10
Do I need to typ this in at run->cmd? Cuz when I typ it in there I get access denied. What to do?
I dont have any backup. I dont need a backup btw
EDIT: Ok i got chkdsk /r /f but he can't run the proces cuz it is already in use and ask me if it I want it to restart the computer and check it but when I restart my computer and checks the hard disk it goes into tilt and does nothing...
cybercore
- Joined
- Jul 7, 2009
- Messages
- 15,612
bootrec.exe /fixmbr
bootrec.exe /fixmbr
- Thread Author
- #12
I did run scannow and it told me some files were damaged and recovered but it didnt fixed the winload.exe error. When I try bootrec.exe in cmd it says it doesn't recognize it as a file.
Is there a solution if I have a cd drive put it in and run it via another computer using my internal network?
cybercore
- Joined
- Jul 7, 2009
- Messages
- 15,612
I would try Windows 7 System Recovery Disc, please read the instructions carefully. Once you can boot from it to the system recovery options, choose Link Removed.
Similar threads
- Replies
- 1
- Views
- 4K
