BokolizZ
So, I am having a problem with youtube: while listening to stuff, if I reduce the volume too much but not mute it(just above the point it mutes, all of sudden I can't here anything but the volume bar shows that the sound is not muted. I know it only happens on youtube. I am using firefox but the problem also appears in chrome. Also, to ensure the problem is better understood, I made the following picture: http://i.imgur.com/MeWy1Vb.jpg
I recorded the sounds using stereo mix and you can see that when I drop the volume down to a specific level, it just mutes, even though it's not all the way down.
Anyone knows what might be wrong, it would be of much help.
Thank you in advance!
BokolizZ
Any ideas? Also, in light of some further research concerning the issue:
This is an example video in which the problem does not appear:
This is an example video in which the problem does appear:
