EMARPEE
Is it possible to connect wan miniport pppoe and wireless lan together in a pc to access internet for load sharing /for increasing the bandwidth ?
Yes, it is possible to connect a WAN Miniport (PPPOE) and a Wireless LAN together on a PC to access the internet for load sharing or to increase bandwidth. This setup is commonly known as "Load Balancing" or "Link Aggregation" where multiple connections are used simultaneously to achieve higher speeds or to distribute the network load across different connections. Here's a general overview of how you can achieve this setup: 1. Connect WAN Miniport (PPPOE) and Wireless LAN: - Set up your WAN Miniport (PPPOE) connection for the primary internet access. - Connect to your Wireless LAN for the secondary internet access. 2. Load Balancing Configuration: - You will need a specialized router or software on your computer to handle...
Yes, it is possible to connect a WAN Miniport (PPPOE) and a Wireless LAN together on a PC to access the internet for load sharing or to increase bandwidth. This setup is commonly known as "Load Balancing" or "Link Aggregation" where multiple connections are used simultaneously to achieve higher speeds or to distribute the network load across different connections. Here's a general overview of how you can achieve this setup: 1. Connect WAN Miniport (PPPOE) and Wireless LAN: - Set up your WAN Miniport (PPPOE) connection for the primary internet access. - Connect to your Wireless LAN for the secondary internet access. 2. Load Balancing Configuration: - You will need a specialized router or software on your computer to handle the load balancing between these connections. - The load balancing software or router will intelligently divide the internet traffic between the WAN Miniport (PPPOE) and Wireless LAN connections. 3. Network Bridge Configuration: - To make use of both connections simultaneously, you may need to set up a network bridge on your PC. - This network bridge will combine the bandwidth of both connections for increased speed and load sharing. 4. Configuration Considerations: - Ensure that your internet service provider (ISP) permits multiple connections for the same account. - Make sure that the load balancing or link aggregation software/router you choose supports the WAN Miniport (PPPOE) and Wireless LAN connections. 5. Testing and Monitoring: - After setting up the connections and configuring the load balancing, test the setup to ensure both connections are working and contributing to the overall bandwidth. - Monitor the performance to see if there is an improvement in speed and network load sharing. It's important to note that setting up such a configuration can be complex and might require specific hardware or software. Additionally, not all ISPs support or allow this type of setup, so it's recommended to check with your ISP before attempting to implement load balancing with multiple connections. If you require more detailed instructions or specific guidance on setting up load balancing with WAN Miniport (PPPOE) and Wireless LAN connections, feel free to ask for further assistance!
