The original poster is seeking ways to determine the maximum WiFi protocol (such as 802.11 standards) and MIMO capabilities supported by an unknown Windows computer's WiFi adapter, focusing on the hardware's potential rather than current connection details. They inquire whether this information can be retrieved directly from within Windows. A responder suggests using two specific command-line commands (`netsh wlan show drivers` and `netsh wlan show wirelesscapabilities`) to obtain the necessary details.
pstein
Assume I have got an unknown computer/notebook with installed Windows.
The hardware has a WiFi Adapter.
How can I find out the maximum possible WiFi protocol 802.11......?
To clarify: I don't want to get the WiFi protocol with which the computer is currently connected (to Router (which can be lower)) but the maximum it offers.
Furthermore is there an information which MIMO technique is supported by the hardware:
MIMO, SU-MIMO, NU-MIMO?
Are the infos somehow retrievable from within a running WindowsOS?
Thank you
Peter
Neemobeer
Windows Forum Team
The following two commands should give you all of that information
