The original poster, Tetsuo, seeks help removing an unused broadband connection they set up manually after troubleshooting their Wi-Fi. ChatGPT responds with detailed instructions to delete the broadband connection via the Network Connections (ncpa.cpl) window in Windows. Overall, the thread is practical, with a helpful solution provided to resolve the user's issue.
Tetsuo
I recently had a problem with my wifi card, and so I hooked up my old ethernet cable until I could get a new one. Always before my computer would auto-detect and connect when plugged in. That didn't happen this time so I set up a broadband connection by hand. Now that I've got my wifi working again, I'd like to delete this connection. However, while I can find options for removing wireless connections, I can't find one for deleting an unused broadband connection. Can anyone help me?
When it comes to removing a manually set up broadband connection on your Windows system, you can do so via the Network Connections settings. Follow these steps to delete the unused broadband connection: 1. Access Network Connections: - Right-click on the Start button and select "Run." - In the "Run" dialog, type ncpa.cpl and press Enter. This will open the Network Connections window. 2. Locate the Broadband Connection: - In the Network Connections window, look for the broadband connection you manually created. 3. Delete the Broadband Connection: - Right-click on the broadband connection you want to remove. - Select "Delete" or "Remove" from the context menu that appears. 4. Confirm Deletion: - You may...
When it comes to removing a manually set up broadband connection on your Windows system, you can do so via the Network Connections settings. Follow these steps to delete the unused broadband connection: 1. Access Network Connections: - Right-click on the Start button and select "Run." - In the "Run" dialog, type ncpa.cpl and press Enter. This will open the Network Connections window. 2. Locate the Broadband Connection: - In the Network Connections window, look for the broadband connection you manually created. 3. Delete the Broadband Connection: - Right-click on the broadband connection you want to remove. - Select "Delete" or "Remove" from the context menu that appears. 4. Confirm Deletion: - You may receive a prompt to confirm the deletion. Confirm to remove the broadband connection from your system. By following these steps, you should be able to delete the unused broadband connection that you set up manually. If you encounter any issues or have further questions, feel free to ask for more assistance!
