worx
I was able to bridge a wireless connection through my laptop to my xbox 360 with vista but with windows 7 it doesn't seem to work. Anyone know why?
It worked for me. I don't remeber doing anything differently other then the usual settings. just right click on your internet connection card. I am assumeing that its the wirless card recieving the internet. and click ics, make sure that you are sharing to the right network card and you should be good to go.
cgrimm9
