GeneralHiningII
- Joined
- Sep 21, 2012
- Messages
- 750
Relevant devices:
Killer e2200 NIC (I know, mistakes were made)
MSI Z87-G45 Motherboard (Ditto)
Current drivers are the up to date (15th Aug 2016) standard drivers found here - Link Removed
I used to use the Killer Suite, it was buggy, so I moved to the drivers-only version (this was when I first built the PC, so ~2013).
Earlier this year, the problem came up. Sometimes, randomly as far as I know, the network adapter stops working - it can't connect to the modem router. I used to be able to get around it by disabling and re-enabling the adapter in Device Manager, but now it doesn't seem to work as well. I can also go into the Network Adapter Settings and 'Diagnose' the connection, which used to work but now it doesn't either.
The couple of times that the Diagnose option worked, it specified that the default gateway was missing. I changed this through the IPv4 settings, but it doesn't stop the PC from randomly losing network connectivity. I have tried disabling random USB controllers and audio devices, which doesn't seem to work either.
Of note, I had the DPC Latency Checker from ages ago (dl here - Link Removed). Average latency for my PC is ~5000 microsec, i.e. red bars. Again, disabling random USB and audio controllers doesn't reduce this latency.
I have tried grounding my motherboard but that didn't seem to work either.
Have you attempted to put the Killer NIC into a different PC such as a friend's PC and attempting to connect to the Internet through your home ISP connection? If you get the same failure, it's either a broken card, or a poorly written NIC driver. The market is flooded with these today, as NIC standards aren't what they used to be on hardware.
That should dumb it down a bit for you.
