Dadda
Guys,
I'm currently having an issue with my Win7 64 bit Pro computer.
Transfers to other computers on my network is slow and sometimes the icon in the taskbar shows that it's disconnecting and reconnecting. I've also noticed that uploads to the internet are either slow or just never complete as the network keeps resetting.
I've also noticed in the System Event Viewer, for the past hour:
- 355 Service Event Errors ID # 7036 (4439 occurances in 7 days); and
- 177 for Service Event Error ID 7042 (1165 occurances in 7 days)
ID 7036 messages alternate between:
The TCP/IP NetBIOS Helper service entered the stopped state.
and
The TCP/IP NetBIOS Helper service entered the running state.
ID 7042 has messages reading:
The TCP/IP NetBIOS Helper service was successfully sent a stop control.
The reason specified was: 0x40030011 [Operating System: Network Connectivity (Planned)]
The other event message which occurs a lot is event 8033 which has 207 occurrances over the past 7 days. It reads:
The browser has forced an election on network \Device\NetBT_Tcpip_{180E5F8A-7005-4484-A0D4-553607321AC0} because a master browser was stopped.
Does the screenshot here http://i989.photobucket.com/albums/af12/Mad_Max_1412/IRC.jpg indicate a conflict on IRQ 16. If so, would that have an impact on these disconnections.
I believe this might be the underlying cause of my slow transfer speeds to my NAS box getting worse as time went on. When I first installed Windows 7, I was getting very good transfer speeds with the occasional slow one, but now I rarely get a good connection on my LAN.
I've installed the latest Realtek Network drivers from the Gigabyte (motherboard) site plus disabled the unused NIC connector.
It seems like you're facing network connectivity issues on your Windows 7 64-bit Pro computer, with slow transfers on your network and disconnections. The events in the System Event Viewer are indicating problems with the TCP/IP NetBIOS Helper service and network browser elections. Let's address the different aspects mentioned:
Network Connectivity Issues:​
  • Slow Transfers and Disconnections:
  • Slow transfers on your network and disconnections could be due to network configuration issues, driver problems, or hardware conflicts.
  • Event Viewer Errors:
  • Event ID 7036: Indicates the TCP/IP NetBIOS Helper service entering a stopped or running state. This service provides support for the NetBIOS over TCP/IP...
  • Event ID 7036: Indicates the TCP/IP NetBIOS Helper service entering a stopped or running state. This service provides support for the NetBIOS over TCP/IP (NetBT) service.
  • Event ID 7042: Notes successful stop control sent to the TCP/IP NetBIOS Helper service for planned network connectivity reasons.
  • Event 8033:
  • Indicates network browser forcing an election because a master browser was stopped.
IRQ Conflict Query:​
  • The screenshot you shared indicates a conflict on IRQ 16. IRQ conflicts can indeed affect system stability, causing various issues including network disruptions. Resolving IRQ conflicts can potentially improve system performance and stability.
Recommendations to Resolve Network Issues:​
  • Resolve IRQ Conflict:
  • Investigate and resolve the IRQ conflict on IRQ 16 to eliminate potential system instability.
  • Driver and Network Settings:
  • Ensure you have installed the latest network drivers. Consider checking for driver updates from the Realtek website as well.
  • Review network adapter settings for any misconfigurations.
  • Network Troubleshooting:
  • Check for physical network issues, like faulty cables or ports.
  • Verify router and switch settings for optimal performance.
  • Network Browser Configuration:
  • Review network browser settings to prevent frequent elections.
Follow-Up Steps:​
  • To effectively troubleshoot and resolve these issues, consider:
  • Conducting a thorough network analysis.
  • Resolving the IRQ conflict if it persists.
  • Updating network drivers from appropriate sources.
  • Performing network diagnostic tests to identify bottlenecks or configuration errors. Addressing these aspects should aid in resolving the network connectivity issues you are experiencing. If you require further assistance or encounter specific challenges during the troubleshooting process, feel free to provide additional details for more tailored support.
