John Clark
I've been having a problem getting my computers to fully connect to each other on the network. My wife has a HP laptop with WIN 10 Home edition. My machine is a desktop with WIN 7 Pro. The desktop can see the laptop but cannot log on or access the laptop, while the laptop can log onto DT and access all shared directories. The info in the Credential managers are correct for both machines.
At one time the machines could access each other but with updates from Microsoft the connections were broken.
Attached are 2 files containing system and network info for both machines. I would like to find out how to solve this problem.
Well the basic process of accessing an SMB resource via NTLMSSP is the following
Client sends a negotiate request
Server sends a negotiate response (to agree on smb version, NTLM mechanism and authentication provider )
Client uses the agreed upon smb version NTLM etc
Server sends a challenge to validate the account is correct, password
The challenge has a server challenge value
The client using the credentials creates a hash from that 16 bit value and sends it in the response
The server also hashes the 16 bit challenge and compares it with what the client is sending
So basically these hashed values are not match
The logical conclusion is the credentials are not correct or the hashing mechanisms are not the same (although for...
Neemobeer
Windows Forum Team
A wireshark capture while attempting to connect would be more helpful as there are many reasons you wouldn't be able to connect.
livix07
Honorable Member
Is NetBIOS over TCP enabled on both computers as in the tutorial below?
Disable NetBIOS over TCP/IP in Windows 7 ent.
Is file and printer sharing TURNED ON on both computers?
is network discovery TURNED ON on both computers?
Are the services below active (running)?
Function Discovery Provider Host (FDPHost)
Function Discovery Resource Publication (FDResPub)
SSDP Discovery Service
What happens when you try to access the shared file/folder by typing the IP address in File Explorer?
something like \\192.168.1.2\shared
John Clark
Disabled NETBios on both machines and all discovery is on. Still status quo. Laptop (WIN 10) automatically sees win 7 machine on bootup but Desktop cannot log onto laptop.
Neemobeer
Windows Forum Team
I see error: STATUS_LOGON_FAILURE
Normally Windows 10 is set to default to NTLMv2 authentication level and Windows 7 is LM NTLM and negotiate NTLMv2. I do see the Windows 7 sending NTLMv2 packets though so I would check and clear out credentials if you have them in "credential manager" in control panel.
livix07
Honorable Member
Sorry but I have asked you to enable NetBios on both computers not to disable.
John Clark
Credentials were listed only on the WIn 7 machine and were removed. Situation is still the same, rebooted to see if that would help but still status quo.
Neemobeer
Windows Forum Team
On Windows 7 try setting
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Lsa\LMCompatibilityLevel to 5
If it still isn't working get another wireshark capture.
Neemobeer
Windows Forum Team
I see you trying to authenticate with a different account with a different machine name. You need to be using credentials that are on the remote machine in the form REMOTECOMPUTERNAME\REMOTEUSER
Neemobeer
Windows Forum Team
Are the times on both machines the same or within 5 minutes? I would try disabling channel binding on the Windows 7 box.
  • Start > Run
  • Type secpol.msc
  • Local Policies > Security Options > Network Security: Exteneded Protection for Authentication
  • Turn the setting on and set it to disabled and reboot
