Rainer Bielefeld
Honorable Member
- Joined
- Sep 22, 2014
- Messages
- 18
A Friend works in a club office. His WIN7-PC was connected to local network and Internet with an USB-WLAN-Stick to a Fritz!Box. Always worked fine, until some day WLAN connection got lost. I tried to help and checked:
Any ideas concerning possible roots for a complete networking loss? Or what I should check additionally?
CU
Rainer
- Something wrong with the USB-WLAN-Stick? No control light on the stick, suspicious extension cable, ... I tried Stick directly at the USB Port, we had contorl light, but noWLAN connection
- We tried a different USB-WLAN-Stick. Nothing doing, did not work.
Stick Worked perfectly with my WIN10-Laptop - I disabled Firewall: no progress
- We tried Cable LAN connection (which worked perfectly with my WIN10 Laptop): no connection.
- I checked LAN adapter: all I saw on screen looked perfect, it was active, ...
CU
Rainer
