snatcher
Hello , when i boot and enter windows 7 , im getting the error "internet explorer has stopped working".
Im using Chrome for browsing. I didnt even opened IE8. This message keeps on comming every 20 seconds after i closed the error. This is very annoying. :mad: Someone who has a solution to this ? Maybe it would help if i uninstall IE8 and instal IE7 ?
Thx in advance !!
It sounds like you're encountering an error related to Internet Explorer even though you primarily use Chrome for browsing. Here are a few steps you can try to troubleshoot and resolve this issue:
Steps to Resolve "Internet Explorer has Stopped Working" Error in Windows 7:​
  • Reset Internet Explorer:
  • Sometimes resetting Internet Explorer settings can help resolve issues. To do this:
  • Open Internet Explorer.
  • Go to Tools (gear icon) > Internet Options.
  • In the Advanced tab, click on Reset.
  • Follow the on-screen instructions to reset Internet Explorer settings.
  • Disable Internet Explorer:
  • You can disable Internet Explorer to prevent the error pop-ups. Here's how:
  • Press Windows Key + R, type...
  • Press Windows Key + R, type appwiz.cpl, and press Enter.
  • Click on "Turn Windows features on or off."
  • Uncheck the box next to Internet Explorer.
  • Click OK and restart your computer.
  • Update Windows:
  • Make sure your Windows 7 is up to date. Updates often include fixes for various issues.
  • Press Windows Key + R, type wuapp, and press Enter.
  • Check for updates and install any available updates.
  • Check for Malware:
  • Malware can sometimes cause unexpected behavior. Run a full system scan with your antivirus software to check for any infections.
  • Try Another Browser:
  • Since you primarily use Chrome, consider using it exclusively and see if the issue persists.
  • Uninstall and Reinstall IE:
  • If none of the above steps work and you prefer to keep Internet Explorer, you can try uninstalling and reinstalling it. Here's how:
  • Click OK, restart your computer, then follow the same steps to enable Internet Explorer.
  • Check Event Viewer:
  • You can also check the Windows Event Viewer to get more information about the error. Look for errors related to Internet Explorer in the logs. By following these steps, you should be able to troubleshoot and resolve the "Internet Explorer has Stopped Working" error on your Windows 7 system. If the issue persists, feel free to provide more details for further assistance!
