The original poster is experiencing driver installation issues with their EW-7612UAn USB device on Windows 7 64-bit, despite it working previously. A detailed troubleshooting response suggests steps like checking Device Manager, uninstalling and reinstalling drivers from the official website, disabling driver signature enforcement, updating Windows, trying different USB ports, running hardware troubleshooters, and contacting support if needed. Overall, the response aims to guide the user through comprehensive methods to resolve their driver installation problem.
babymalady
i am having problems installing EW-7612UAn driver on my windows 7 64bit OS. when i inserted the USB EW-7612UAn, nothing happens, it does not install. when i manually installed the driver, it says device driver software was not successfully installed. The same thing happened on my laptop when i inserted the usb EW-7612UAn. it worked fine before but now something went wrong and won't install. i tried using system restore but to no avail. please help. thank you
It seems like you're encountering issues with installing the EW-7612UAn driver on your Windows 7 64-bit OS, and the driver installation is failing. Here are some steps you can take to troubleshoot this problem: 1. Check Device Manager: - Open Device Manager by right-clicking on "Computer" or "This PC," selecting "Manage," then clicking on "Device Manager" in the left pane. - Look for any entries with a yellow exclamation mark, which indicates a problem with the driver installation. 2. Uninstall the Current Driver: - In the Device Manager, locate the EW-7612UAn device, right-click on it, and select "Uninstall." - Make sure to check the box that says "Delete the driver software for this device" if available. - After...
It seems like you're encountering issues with installing the EW-7612UAn driver on your Windows 7 64-bit OS, and the driver installation is failing. Here are some steps you can take to troubleshoot this problem: 1. Check Device Manager: - Open Device Manager by right-clicking on "Computer" or "This PC," selecting "Manage," then clicking on "Device Manager" in the left pane. - Look for any entries with a yellow exclamation mark, which indicates a problem with the driver installation. 2. Uninstall the Current Driver: - In the Device Manager, locate the EW-7612UAn device, right-click on it, and select "Uninstall." - Make sure to check the box that says "Delete the driver software for this device" if available. - After uninstalling, unplug the EW-7612UAn device and restart your computer. 3. Reinstall the Driver: - Visit the official Edimax website and download the latest driver for the EW-7612UAn that is compatible with Windows 7 64-bit. - Once downloaded, install the driver by running the installer executable file. 4. Disable Driver Signature Enforcement: - Sometimes, driver installations fail due to driver signature enforcement. You can temporarily disable this feature to see if it helps with the installation. - Restart your computer, press F8 during the boot process, and choose "Disable Driver Signature Enforcement" from the advanced boot options. 5. Update Windows: - Make sure your Windows 7 operating system is up to date by installing all available updates through Windows Update. - Some driver issues could be resolved by updating the operating system. 6. Try a Different USB Port: - Plug the EW-7612UAn into a different USB port on your computer to rule out any issues with the USB port itself. 7. Run the Hardware and Devices Troubleshooter: - Open the Control Panel, go to "Troubleshooting," then click on "Hardware and Sound," and select "Configure a device." - Follow the on-screen instructions to run the troubleshooter and see if it can detect and fix any issues with the device. 8. Contact Edimax Support: - If the issue persists after trying the above steps, consider reaching out to Edimax customer support for further assistance with the driver installation issue. By following these steps, you should be able to troubleshoot and resolve the driver installation problem with the EW-7612UAn on your Windows 7 64-bit system.
