GusG
Hello guys I have a problem with WAP 4035. When i type the internal ip address and then the box appers I type on username and password admin/admin but it gives me this error [h=1]HTTP/1.0 401 Authorization Required[/h]I have already reseted my WAP 4035 but the problem remains ... Do you have any idea how can I solve this ???
It seems like you are encountering an "HTTP/1.0 401 Authorization Required" error when trying to access your WAP 4035 device using the default credentials. This error typically indicates that the server is requiring authentication for access. Here are some steps you can take to troubleshoot and potentially resolve this issue: 1. Check Default Credentials: - Ensure that you are using the correct default username and password. While "admin/admin" is commonly used for login, it's possible that the credentials have been changed. You can check the device manual or the manufacturer's website for the correct credentials. 2. Verify Network Connectivity: - Make sure that your device is connected to the network correctly and that...
It seems like you are encountering an "HTTP/1.0 401 Authorization Required" error when trying to access your WAP 4035 device using the default credentials. This error typically indicates that the server is requiring authentication for access. Here are some steps you can take to troubleshoot and potentially resolve this issue: 1. Check Default Credentials: - Ensure that you are using the correct default username and password. While "admin/admin" is commonly used for login, it's possible that the credentials have been changed. You can check the device manual or the manufacturer's website for the correct credentials. 2. Verify Network Connectivity: - Make sure that your device is connected to the network correctly and that there are no network issues preventing access to the device. 3. Try Different Browsers or Devices: - Sometimes browsers or devices can cause login issues. Try accessing the WAP 4035 using a different web browser or from a different device to see if the issue persists. 4. Clear Browser Cache and Cookies: - Clearing your browser's cache and cookies can sometimes resolve login issues. It helps in ensuring that you are accessing the device login page without any stored login data conflicts. 5. Reset the Device to Factory Settings: - If none of the above steps work, you can perform a factory reset on the WAP 4035 device. This will revert all settings back to default, including the login credentials. Ensure to follow the correct procedure for resetting the device. 6. Contact Manufacturer Support: - If the issue persists after trying the above steps, it's recommended to contact the manufacturer's support for further assistance. They should be able to provide specific guidance on how to resolve the login issue with your WAP 4035 device. By following these steps, you should be able to troubleshoot the "HTTP/1.0 401 Authorization Required" error and regain access to your WAP 4035 device.
