clim920
Well i just recently upgraded to windows 7 and i was on vista prior to that, now i am on win 7 and i plug in my retail plus wireless usb adapter to get my router wifi it says device connected please wait while windows finds and installs the drivers, so it stops 5 seconds later and it says no drivers found. :( i tried it on device manager and find drivers that way didnt work. i looked on the companies site for them none there........ anything i can do or am i internetless :(:(:(
Could you please fill in your computer specs in the UserCP link at the top left hand side of the page.
Then click Edit Your Details.
This freeware program will give you all the information you will need:
SIV (System Information Viewer) 4.03
This will give us a better understanding of yourc omputer and the components in it
clim920
No its Retailplus look it up on google ull see there product site
Please helpp :"(
clim920
arghhh no one had this issue or has seen this issue or knows anything about it?!?!?! plssssss
reghakr
Well,. it's been called a very cheap card and it supposedly supports Vista,. but I could bot locate any drivers.
reghakr
