The forum thread addresses a Windows user experiencing Wi-Fi connectivity issues, specifically limited connectivity and invalid IP configuration after initial success. Multiple users, including the original poster, discuss troubleshooting steps like resetting network settings, disabling IPv6, and deleting specific network adapters, with guidance on how to perform these actions. Overall, the conversation is troubleshooting-oriented with helpful tips and clarifications, but the original issue remains unresolved within the thread.
help needed
hi guys,
I bought a Lenovo laptop 3 moths ago and it was connecting fine to my wifi network until the day before yesterday..
since then it connects to my wifi network but shows limited connectivity and invalid ip configuration..please help asap
things I tried were
-resetting the router
-changing ipv4 settings
-did a factory data reset...
the model of the laptop is g510 and it has a QUALCOMM Atheros chip
my ipconfig/all info is attached...
please help asap..it will be much apprieciated.
also I have already tried everything on this forum..
Could you please open
Device Manager
Expand Network adapters
Right click the problem WiFi adapter and choose properties.
Select the Driver tab
AND
See if the option to "Roll Back Driver" is available"
If so, perhaps rolling back the driver for your wireless adapter might provide some relief.
As you can see from the results of you ipconfig.txt file, the OS is generating an APIPA (automatic private IP address) in the 169.254 range and that means that it is not receiving DHCP information from your phone which is (I presume) acting as your router in this instance.
I just performed a test with my Windows Phone 8.1 and my wife's wireless windows 7 machine upstairs which worked perfectly. I've attached an image of my ip results along side of...
patcooke
Microsoft MVP
Microsoft MVP
Aplogies to "help needed" - I suspect it was me who originally banned this post as spam when I saw the expression "my wifi network" and misread it as "my wifi router" which is a subject of masses of spam posts. My apologies.
patcooke
Microsoft MVP
Microsoft MVP
The Autoconfiguration IPv4 Address. . : 169.254.245.253(Preferred) means that your device is not being assigned a valid IP address via DHCP - addresses starting with 169 are "autoconfigured" by the device when DHCP fails)
Suggest you:
1. delete the Wireless LAN adapter Local Area Connection* 4.
2. Remove IPv6 from the Qualcomm Atheros AR9485WB-EG Wireless Network Adapter
Restart and check the IPv4 address assigned to the device to see if it is still beginning with 169.
help needed
Thread Author #6
Suggest you:
Please help me on the subjEct on how to do that...please...please..
patcooke
Microsoft MVP
Microsoft MVP
1. Goto control panel, view by large icons, network and sharing centre, change adapter settings, delete local area conection 4.
2. Goto control panel, view by large icons, network and sharing centre, change adapter settings, right click on wifi, select properties, clickon networking tab, scroll down to tcp/ipv6 (NOT 4). Uncheck the box at the left of it.
3. Scroll all the way back out and reboot.
If stillnot sorted attach a new copy of the ipconfig report.
help needed
Thread Author #8
Thanks I got it but I couldn't find the land adapter anywhere
help needed
Thread Author #11
It's probably referred to as Local Area Connection* 4.
Yeah...not there...althoughni fixed the problem by removing tcpv6
help needed
Thread Author #16
hi i am again in need of your help ...sorry for the late reply but it was fixed but it happened again..please help..
my ipconfig/all is attached.
Trouble
Noob Whisperer
Tried that already..any other suggestions..?
That certainly isn't reflected in the text file you attached to your previous post.
IF it is disabled now then could we please see a config file that reflects that?
AND
I'm not sure what this is
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Remote NDIS based Internet Sharing Device
But you might want to try disabling it.
If your primary concern is you wifi connection then narrowing the focus by eliminating extraneous devices like wired Ethernet might at least help to concentrate the diagnostics.
