velectro
Hi all
I am having the Linksys WMP54G issue of dropped signal etc, that a lot of people seem to have. I have tried the various solutions people have proposed, but no luck so far, so i'll just buy a new PCI card. I love 7 so much and don't want to go back to xp just because of 1 component.
So, my question is, which PCI wireless cards are known to run absolutely fine with 7? (32bit)
Hi, currently back to a wired connection. anyone got any suggestions?
am sick of fighting on trying to get linksys to work, i really dont mind buying another card at this point - which cards do people use?
thanks
kevin from Chi-town
trya search with your pci card in the above navbar...But before you go buy a card...maybe take a look at this. Your not the only one w/this prob, other a trying avenues like this
Sry...heres the link Link Removed - Invalid URL
velectro
thanks for posting :) that site is for the 64bit version,and i am running the 32bit one, however, i'll have a read and see if i can work something out
reghakr
You might want to check here if no Windows 7 driver is available
Microsoft's site gives a direct link to the manufacture if supported.
velectro
I'm currently using the vista (card is ver.4.1) driver, and the connection works when it feels like it!
I tried the solution on the other web site using the ralink stuff but that was no better than above. maybe i need to re-format, fresh install and try the ralink stuff again. by now, theres probably god knows what bits of drivers scattered everywhere!
velectro
thanks
