The WindowsForum thread discusses a user experiencing connectivity issues with a Wi-Fi adapter on Windows XP, including problems with network certificates and inability to access web pages. The user seeks help, mentioning that the system reports needing a wired connection and citing a certificate error, which causes confusion since Wi-Fi should work without one. Respondents suggest checking the Wi-Fi security settings, specifically recommending WPA2 PSK, and clarify that a wired connection isn't necessary, with ongoing troubleshooting and communication happening through the forum and potentially via social media. Overall, the tone is of a troubleshooting exchange focusing on resolving Wi-Fi connectivity problems.
musovboro
Hi. Ive tried setting up a wifi adapter on win xp. It says im connected but im not getting any web pages at all. Can Anyone pls help. Many thanks
Sent from my SM-G925F using Windows Forums mobile app
nmsuk
Can you open a command prompt(admin) and run ipconfig .all and post the output here.
nmsuk
How's the WiFi secured.
Sent from my CLT-L09 using Tapatalk
nmsuk
Have you tried WPA2 PSK shouldn't need a certificate just the wifi password.
musovboro
Thread Author #8
Its says in the instructions that I need a wired connection for it to work. Defeats the purpose of having wifi lol
nmsuk
You don't need a wired connection for it to work. What instructions are these?
nmsuk
You may have. A Richard by any chance
musovboro
Thread Author #12
Yes RP. I'm trying to connect with Ethernet cable but no web pages will load up. I've checked auto detect settings on LAN too and still nothing
nmsuk
Can you do an ipconfig /all in an admin command prompt and post it here. Oh and I'm going to remove my name from your post.
nmsuk
yes just type ipconfig /all will show your configured networts
nmsuk
No problem.
