tobwen
Well-Known Member
Users cannot (at least in v2004) allow Quality=Security Updates but disable Feature updates (=to next major release).
Is this correct?
Neemobeer
Windows Forum Team
Yes and no. The updates themselves are independent of the upgrades (1909, 2004 etc); however, each release of Windows 10 is only supported for 18 months at which point you need to upgrade to continue receiving patches.
tobwen
Well-Known Member
That was not an answer to my question.
Ok, I ask in another way:
If I disable Security Service(s) (with e.g. Sordum Windows Update Blocker tool) :
Will the Quality/Security Updates delivered or not?
