danbatto
- Joined
- Dec 3, 2014
- Messages
- 1
Hi basically i was using my computer and all was fine it was running windows xp pro i read about ubuntu and decided it was a smart idea, obviously it was and my system can handle it now its a useless pile of junk i had an xp bootable usb drive but it starts to start the setup then i get a blue screen error ive done some searching and all i can come up with is
If you are trying to install the Windows XP from scratch on the laptop, please BE SURE that you put the Hard Drive on "Compatibility" mode in BIOS, which was defaulted to "AHCI" (Compatibility is also known as IDE).
Otherwise, you will experience the "blue screen" issue. To change that setting, you need to do the following:
1. Press F2 when booting up the computer
2. Select 'Config', then 'Serial ATA (SATA)'
3. Change controller option to 'Compatibility' / 'IDE'
which i saw online i havent been able to do any of this because my bios settings dont have any of these things to change they are much more limited than any bios i see on the internet ect im so confused and dont know what to do any help would be so great thanks dan
