Fix Print Spooler Issues on Windows 11 - Step-by-Step Guide
Are you experiencing print spooler issues on Windows 11 and looking for a solution? Look no further! In this tutorial, we will walk you through some potential fixes for print spooler issues on Windows 11. This guide is suitable for beginner to intermediate users.
  1. Restart the print spooler service: Open the Services app (search for "Services" in the Start menu) and locate the "Print Spooler" service. Right-click on it and select "Restart."
  2. Clear the print spooler queue: Open the Services app and stop the Print Spooler service. Then navigate to C:\Windows\System32\spool\PRINTERS and delete all the files in the folder. Restart the Print Spooler service.
  3. Run the built-in Print Spooler troubleshooter: Open the Settings app and navigate to Update & Security > Troubleshoot. Under "Find and fix other problems," select "Printing."
  4. Uninstall and reinstall the printer driver: From the Device Manager, locate the printer driver and right-click on it to select "Uninstall." Then, restart your computer and reinstall the latest version of the driver from the manufacturer's website.
  5. Perform a System Restore: If the problem started after a specific event (such as installing new software or updating Windows), you can use the System Restore feature to roll back your computer to a previous state.
  6. Run sfc /scannow command: Run Command prompt as administrator, type sfc /scannow and press enter. This command will scan for any system files that are corrupted and will try to fix them.
It's also recommended to make sure that your Windows 11 is up-to-date, as well as your printer driver.
Advanced troubleshooting steps:
  1. Check for conflicting software: Sometimes, third-party software can interfere with the print spooler service. If you suspect this may be the case, try disabling or uninstalling any recently installed software.
  2. Check for malware: Malware can also cause print spooler issues. Run a full system scan using your antivirus software to check for and remove any malware.
  3. Check the print spooler logs: The print spooler service generates log files that can help troubleshoot issues. Navigate to C:\Windows\System32\spool\PRINTERS and check the log files for any errors or warnings.
  4. Check for updates and hotfixes: Microsoft releases updates and hotfixes to address known issues with the print spooler service. Check Windows Update to see if there are any updates or hotfixes available for your version of Windows 11.
If none of these solutions work, you may need to contact Microsoft support or the manufacturer of your printer for further assistance.
Top Bottom
