The thread discusses a user's difficulty in customizing tile placement within groups on their Windows interface, specifically wanting to arrange tiles in only three columns without automatic shifting. A responder explains that tile spacing is determined by a pattern based on tile sizes and suggests that third-party applications may be needed for more precise customization. The original poster acknowledges the explanation and thanks the respondent.
Bekrah
I want to be able to choose where my tiles go when placed inside of a group. Notice the screenshot below. I would like the Left4Dead 2 tile and the StarCraft 2 to be placed right below the Batman tile (which would give me only 3 columns but every time I placed them there, then 2 more tiles automatically shift over forcing a forth unwanted column. Is there any way to counteract this so that I can achieve only 3 columns if that's what I desire?
Thanks.
the spacing is grouped by 2 small or one large tile wide with the pattern repeating itself across and down the screen. 3 Tiles wide just won't go unless there is a third party app available which does something like that.
