randycmj98
I need help here ! I cant get this " 1 " back straight . Most of the word i view in internet and games is all in Italic .
Any suggestion to help me out ?
Link Removed due to 404 Error
Try right-clicking on the desktop and choose personalize. Now click the Windows color entry, the the Advanced appearance settings and change the fonts here.
Don't mess around with any other entries as you will loose he Aero effects.
Now exit out and see if thisfthe problem./
reghakr
randycmj98
Yes. i still have that problem . By the way, i have missing font dont know whether u can send me anot if u have it ?
randycmj98
Just wondering if you installed some sort or desktop publishing software and then uninstalled it and wiped out those fonts because the program put them there.........justa a wild guess.
Perform a search for this file:
fms_metadata.xml
i found this post . That you post it .
Its is this problem ... i uninstall left 4 dead. Its remove my tahoma fonts then my font all become italic ..
i dont know how to repair it ..
randycmj98
What did you uninstall?
If you know the font names I can upload them for you.
I uninstall left 4 dead then it uninstall my tahoma font. i get it back but still italic.
Do you have all window 7 font ? maybe u send me all i try see whether can ?
reghakr
Packed size ids 197,850.871KB..............way to large to upload
I looked in the registry, I think I know which ones you need..
Hang on, it will take a while
Still too big 6.30MB
Tyhe fonts you need are
Calibri
Cambria
Consolas
Georgia
Segoe UI Symbol
Verdana
You can find them ion the Internet
randycmj98
Calibri
Cambria
Consolas
Georgia
Segoe UI Symbol
Verdana
Where do you find the registry
reghakr
It was under HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Font Management
reghakr
You don't want to mess with the registry, it's om;y for advanced users.
