gbalonek
Is it possible to have a separate All Programs Menu that another account user?
I don't know of any way you are needing. However, there is a compromise, which may not be what you are looking for. I have five grandchildren, all of whom use one of the computers in my house on their visits. This is what I have done. Let us assume that you have two accounts you wish to isolate.
Open Program Data - Microsoft - Windows - Start Menu.
Create two new folders in "Programs", say gbalonek and other.
Now open "programs" and carefully drag the item you need to each specific folder you have . Copy at this stage, do not move, in case you make a mistake.
Now, when you open the "All Programs" you will find those two folders there, with contents. You can tidy up by dragging and dropping from withing the "All Programs" item.
davehc
rsvr85
@ davehc, that seems a really long-winded way of doing it!!
@ gbalonek, navigate your way to;
A:\Users\Home\AppData\Roaming\Microsoft\Windows\Start Menu - This is other users' start menu.
If you go to;
A:\ProgramData\Microsoft\Windows\Start Menu\Programs - That'll be your start menu
