Neji
I'm wondering if there is a way to change the options for when you right click on the taskbar. On XP, when you right click on a tab the menu box popped up to the right,, on 7 it pops up above. I've gotten used to closing windows by right clicking and pressing close, so it's a bit of an annoyance to have to move the mouse up. Nothing major and something I can probably get used to but would prefer it the old way.
Thanks
To adjust the behavior of the taskbar when you right-click on it in Windows 7, you can make some modifications using third-party tools. Here's how you can potentially achieve what you're looking for:
Using Taskbar Tweaker:​
  • Download Taskbar Tweaker: You can use a tool like "Taskbar Tweaker" to customize the taskbar behavior.
  • Install and Run: After downloading, install the tool and run it.
  • Adjust Taskbar Behavior: Look for options within the tool that allow you to customize the taskbar behavior on right-click.
    Alternative Solutions:​
    Another approach could involve using software that allows you to customize Windows features extensively such as "AutoHotkey", where you can create custom scripts to...
    Another approach could involve using software that allows you to customize Windows features extensively such as "AutoHotkey", where you can create custom scripts to modify the behavior of the taskbar.
    Please Note:​
  • When using third-party tools or scripts to tweak system behavior, always ensure they are from reputable sources to avoid any security risks.
  • Always verify the compatibility of the tools with your specific version of Windows 7 before making any changes. If you need further assistance or recommendations on specific tools to achieve this customization, feel free to ask!
