Winger
Every time I change to a different theme it changes my logon screen back to the default, how do I stop this behavior so themes leave my logon screen alone?
When changing themes in Windows, it's common for the logon screen to revert to the default background. This behavior occurs because the logon screen background is tied to the system files that are not affected by theme changes. To prevent themes from affecting your logon screen background, you can follow these steps:
Method 1: Using Group Policy Editor​
  • Open Group Policy Editor:
  • Press Windows Key + R, type gpedit.msc, and press Enter.
  • Navigate to the Setting:
  • Go to Computer Configuration > Administrative Templates > Control Panel > Personalization.
  • Disable the Setting:
  • Find the setting named "Do not display the lock screen" and double-click on it.
  • Select...
  • Select Enabled to disable the lock screen.
Method 2: Tweaking Registry Settings​
  • Open Registry Editor:
  • Press Windows Key + R, type regedit, and press Enter.
  • Navigate to the Key:
  • Go to HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\System.
  • Create a New DWORD Value:
  • Right-click on the right pane, choose New > DWORD (32-bit) Value.
  • Name it DisableLogonBackgroundImage and set its value to 1.
Important Note:​
  • It's crucial to create a system restore point before making changes to the Group Policy Editor or Registry. This ensures you can restore your system if anything goes wrong.
  • Make sure you have administrative privileges to make changes to Group Policy Editor and Registry. By following these steps, you can prevent themes from affecting your logon screen background in Windows.
