Mike
Windows Forum Admin
Please see announcement:
Kindest Regards,
Just to add Rich and I have been approving posts like the one above:
Is this normal? Surely not..
Correct Explanation: Forum Announcements and Feedback Forum were set to throw all attachments, posts, and threads into auto-moderation. This was an error on this site. I was mistaken regarding this. This is not a problem that will re-occur. Simply put, normal members cannot make announcements, but they should be able to reply to them and post attachments. In the Feedback Forum, anyone can post a thread/post/attachment. These issues have been resolved as of March 31 2:05 GMT -5. As you know, the Forum Announcements and Feedback Forum have not been used as often here as on Windows7Forums.com, and so...
Mike
Windows Forum Admin
The Log In boxes do not behave the same. Clicking on the box used to removed the text so you could enter you user name, but now it does not, and clicking the password box does not enter the encrypted password.
This was actually absolutely imperative to fix because of the second part re: password box.
This should now be fixed. Please confirm if you see this problem again.
Mike
Windows Forum Admin
OK..I reset IE to default settings and the forum header is back...but everything else I mentioned is still not working.
Surely it is not like this ALL the time? I may need to ask you questions directly over Skype to find out what is going on here. On my end this has never happened unless NetDNA/MaxCDN was down, and even then... that is what you are seeing is the lack of image content because you are not reaching the primary CDN.
You'll notice these images resolve to cdn.windows8forums.com. I will need to look at this with you if this is on a continual basis. This is bizarre beyond description. I suspect most visitors are not seeing this.
Jimbo22
Nah..it was just for those few hours that I discovered it with IE 10 in desktop mode. Since the IE factory reset all is back to normal, but I could figure out why it happened in the first place.
Hey, my accordion look and feel is gone, so kudos for that much. I sure do miss the quick reply box, but I guess I'll have to get used to this way. Oh, btw, if you want to respond to a post and highlight some text of that post and then click on "quote selected text", the quick reply box shows up...so that's how I reply to post now...I just accidentally stumbled a crossed it. It works great for my needs...a bit akward...but I'm good with it.
davehc
Insert inline in the Asset Manager and double-click the image in WYSIWIG mode
I wasn't fully sure what the asset manager was, but disregard my comment, I have sorted it out now. Ignore the picture, it was only to test the adjustment.
On other forums, I have always uploaded a picture, and then arranged its final position with spacing and then the paper clip. It seems to be a slight different procedure here, which I confess I had not noticed. (Insert image)
Jimbo22
Well got up this morning and turned on PC, started my usual forum rounds....and damned if the page load accordion effect is back....and back on all browsers. Still no quick reply box.
Now the log out option doesn't work...it goes through the process but when you follow the link to go back, or just use the go back arrow or close and reopen browser, it still comes back as logged in/on...so you can't log out.
Saltgrass
This doesn't need to be posted, but right now, on the Windows 7 forum, I am getting the following types of errors when I try to go there. It was working fine 20 minutes ago.
Fatal error: Out of memory (allocated 114032640) (tried to allocate 82 bytes) in /home/w7/public_html/dbtech/vboptimise/includes/operators/xcache.php on line 38
Fatal error: Out of memory (allocated 108527616) (tried to allocate 4194304 bytes) in /home/w7/public_html/dbtech/vboptimise/includes/operators/xcache.php on line 38
Mike
Windows Forum Admin
All issues related to these changes should be properly fixed. The Singapore CDN edge server is also online for Windows7Forums.com (It appears we have more Asian traffic going to that site). We are now looking at a stage 2 solution to integrate both sites. Please confirm that the majority of the issues you have noticed are resolved. As we are close to moving on to the next round of changes, we are looking to minimize/end the stratification between the two sites on a more permanent basis and possibly change the forum software we are using. Although this is dependent on many variables. Simply put, stage 1 was a plan put in place very quickly to decrease page load times. Stage 2 is a plan to get everyone on the same page... no pun intended.
Jimbo22
Yep...everything seems to be back to normal....
OK...suggestion; when you make changes like this, how about putting something under neath the forum header telling everyone that the site is going in for some maintenance and there might be some issues with some aspects on both sites until the maintenance is completely finished. A heads up if you will, so the forum members wont be so shell shocked when it goes all haywire...
whs
One thing I noticed is that my postings and answers do not show up any more in "Subscribed Threads". And that is pretty annoying because I now have to go to my profile to find the threads on which I posted.
davehc
That's a baddy1 I am just testing now to se if it your settings or across the board.
P.S. Later. Nope. Ok here.
Jimbo22
First try ctrl F5 to refresh the page, then try logging out/in, or try removing the cookies.
davehc
OK. I have refreshed and logged out and in. here goes.
Nope. Fine. This post is subscribed.
I don't want to test by removing the cookies. In my instance, that gets me this infernal "waiting for a moderators approval " thing. Happens to me weekly, when I put my image back.
I have my settings set as this:
When I pop into the forum i click on settings, top right, and there will be any threads I'm subscribed to. (this also stops the annoying email notification)
davehc
Possibly another bug?
I was surprised, when I came to the forums yesterday, to find an unusually large number of new posts, under the "whats new" item. Quick scan, Into "Forum Actions" and marked forums read.
When I came back, early today, all the posts were still there. I repeated the "Forum actions" closed and opened again, and the posts were still there. Repeated attempts showed that I was unable the clear the old posts. ??
Added later. I found a way. I had to re-enter twice, and do a "Refresh". I was then able to mark the forums read.
P.S. The Problem was gone, this time around!
Jimbo22
Another bug; the "new post" tab still has post in it from over a week ago. It's not acting like it did before. When viewing the new posts, the total would dwindle down but it just seems to keep growing with older and older posts.
davehc
That's interesting, Bass. Looks very much like my problem (see post above) I thought I stood alone!
Mitchell_A
Former Moderator
Ditto. I thought maybe it was because I hadn't been visiting the site often but this definitely reaffirms.
Mike
Windows Forum Admin
Reading these posts certainly removes them once they've been read. Your session timeout is 1 day as opposed to 1 hour now, so you will not be logged out so quickly unless you explicitly log out. Thus, New Posts is affected by this. Terms like "since your last visit" take into consideration last activity, which does mean the last time you were logged out at this time. There is a hard limit to how many posts will be displayed on this page, so if you keep seeing what appears to be an unlimited number of posts, this is because a lot of posts have actually been written since that time.
