The user reports recurring pop-up messages related to Adobe Flash Player since moving to the UK, which can be dismissed temporarily but reappear frequently. A suggested solution from another user is to update or reinstall Flash Player, and the original poster confirms that doing so temporarily resolved the issue, though the exact cause remains unclear. Overall, the thread discusses troubleshooting persistent Flash Player notifications with a brief, tentative resolution.
krosslin
Banned
for the past few weeks (ever since I moved to UK), I've been getting this message a couple times every day
It comes up, I press "dismiss all" or "continue" or the red cross, and no matter what I press it appears 2 or 3 times more and I have to close it again
after that everything works fine
