The thread discusses the difficulty in finding a compatible charging cable for a Samsung Galaxy Tab S3. The original poster, MikeHawthorne, clarifies he's searching for a symmetrical, reversible connector similar to the one on his current 4' cord, but has only found wedge-shaped plugs that only fit one way. A responder suggests checking eBay for OEM Samsung cables, indicating that sourcing the exact reversible connector is challenging but possible through third-party or original components. Overall, the conversation reflects common difficulties in obtaining the correct charging accessories for specific devices.
MikeHawthorne
Hi
I'm trying to get a 6' charging cable for my Samsung Galaxy Tab S3.
After a lot of looking I ordered one from Amazon that said that it would work with a Samsung Galaxy S3.
It does not have the correct plug on the end that plugs into the tablet.
I need the kind of plug that is symmetrical, the 4' cord I have can be plugged in either way, there's no top or bottom.
I've looked and looked but I can't figure out what this plug is called?
All the cords seem to come with the wedge shaped end, one side is longer then the other so it only goes in one way.
This on is just rounded on the ends and can go in either way.
It's driving me crazy trying to find the correct cord.
Mike
