The original poster reports that their Fujitsu Lifebook A530's display is excessively bright and painful to watch, especially at night, and mentions trying the function keys without success. A responder (ChatGPT) provides detailed alternative solutions, including adjusting brightness through the Control Panel, power plan settings, updating graphics drivers, using display settings or third-party software, and considering built-in features like Night Light. Overall, the thread centers on troubleshooting and resolving the overly bright display, with the sentiment being that multiple software and system adjustments can help address the issue beyond using physical buttons.
Commander_Cool
The display on my Fujitsu Lifebook A530 is so bright it's actually painful to watch. Especially at night.
I have tried the F6-F9 keys (marked ▼ ▲ ▼ ▲) that I think are supposed to adjust brightness/contrast but no go.
Any ideas as to what to do? Yeah, shades - but that somehow seems so low-tech.
If you're experiencing excessively bright display on your Fujitsu Lifebook A530 and adjusting the brightness using the function keys isn't working, there are alternative methods you can try to reduce the brightness. Here are a few steps you can take to address the issue:
Adjust Brightness through Control Panel:​
  • Control Panel Method:
  • Right-click on the desktop and select "Display settings" or go to Control Panel > Hardware and Sound > Power Options.
  • Look for the display brightness settings and adjust them accordingly.
    Using Power Plan Settings:​
  • Power Plan Settings:
  • Go to Control Panel > Hardware and Sound > Power Options.
  • Select your current power plan and choose "Change plan settings."...
  • Click on "Change advanced power settings."
  • Look for the display brightness settings in the list and adjust them.
    Update Graphics Drivers:​
  • Update Graphics Drivers:
  • Outdated or corrupted graphics drivers can sometimes cause display issues. Ensure your graphics drivers are up to date.
    Using Display Settings:​
  • Display Settings:
  • Right-click on the desktop and select "Display settings."
  • Look for the brightness slider and adjust it to a more comfortable level.
    Third-Party Software:​
  • Third-Party Software:
  • Consider using third-party software that allows more precise control over display settings, such as f.lux or Redshift.
    Additional Tips:​
  • Night Light Feature: Some systems have a built-in feature like Night Light that reduces blue light emission, making it easier to view the screen in low-light conditions.
  • Physical Lighting: Adjusting the surrounding lighting conditions can also help reduce the strain caused by a bright screen. If these steps do not resolve the issue, it's advisable to contact Fujitsu support or a computer technician for further assistance.
