The original poster is annoyed by a feature on their Android keyboard that suggests images or emojis when typing, which causes accidental presses and clutter. They ask for the name of this feature and how to turn it off; they also note an unusual "Microsoft" label on their space bar. In response, ChatGPT explains that the feature is likely "Text Suggestions with Emoji" in Gboard and provides detailed steps to disable emoji suggestions, aiming to help the user resolve their issue. Overall, the thread centers on disabling unwanted emoji/image suggestions on Android keyboards.
anotherwindowsuser
Well-Known Member
An image from 'Images in auto type'. Mobile screen showing a keyboard with predictive text suggesting 'Flow' while typing.
So as you can see when I type a word it creates a suggestion for an image as a representation of the word however I don't like this as I'm forever hitting the wrong button accidentally and after typing a lengthy sentence I then have to prat about removing the images. Does anyone know what this feature is called and how to disable it? Also bit odd this keyboard space bar says Microsoft on my Android phone?? Thanks in advance.
The feature you are referring to is called "Text Suggestions with Emoji" on Android devices. This feature suggests emoji based on the text you type. It's part of the Gboard keyboard by Google which integrates emoji suggestions with text predictions. To disable the emoji suggestions when typing on Android using the Gboard keyboard, you can follow these steps: 1. Open Keyboard Settings: - Go to the app where you use the keyboard (like Messaging, WhatsApp, etc. to open the keyboard. - Long-press on the comma key (or the emoji key, depending on your keyboard settings) to access keyboard settings. 2. Access Gboard Settings: - Select the gear icon to access Gboard settings. 3. Turn Off Emoji Suggestions: - Look for the "Text...
The feature you are referring to is called "Text Suggestions with Emoji" on Android devices. This feature suggests emoji based on the text you type. It's part of the Gboard keyboard by Google which integrates emoji suggestions with text predictions. To disable the emoji suggestions when typing on Android using the Gboard keyboard, you can follow these steps: 1. Open Keyboard Settings: - Go to the app where you use the keyboard (like Messaging, WhatsApp, etc. to open the keyboard. - Long-press on the comma key (or the emoji key, depending on your keyboard settings) to access keyboard settings. 2. Access Gboard Settings: - Select the gear icon to access Gboard settings. 3. Turn Off Emoji Suggestions: - Look for the "Text Suggestions with Emoji" or similar option in the settings. - Disable or toggle off this setting to turn off emoji suggestions. 4. Save Changes: - Exit the settings, and the changes you've made should now disable the emoji suggestions with text predictions. If you are unable to find this option in the Gboard settings, the configuration may vary slightly depending on the version of Gboard and the Android device you are using. By following these steps, you should be able to disable the emoji suggestions with text predictions on your Android keyboard.
