RUDY03
- Joined
- Jul 27, 2016
- Messages
- 81
Hello people!
I have two internet systems at home. The first is a Vodafone mobile router, which is limited to 8GB per month, and gives a fine speed of around 7 Mbps according to speedtest.net and I have a second broadband connection at home which can be used as Wi-Fi as well as be plugged-in to my PC for the internet.
Now, every time I test the Broadband on Speedtest.net and such similar internet speed testing websites, I get speeds around 30Mbps and ping is under 0 (yes <0). If such is the case, then can someone please explain as to why I can NOT play any multiplayer games due to extreme lag on the broadband, but I can easily play with the other Wi-Fi at only 6Mbps, but not at 30 Mbps? Remember, I am using the other router only for comparison.
Also, when I'm downloading something, on Firefox, the browser I use to download, speeds are always stuck up between 50-75 kbps but using the Vodafone router, speeds vary according to which site I'm downloading from, but are very high in comparison to the broadband connection. So, can someone explain exactly why Speedtest results are very satisfying but actual field tests are more than depressing?
P.S. 1 GB download takes about 6 hours and at night, they take about 2 hours but on Vodafone, they take less than 30 minutes. Any valid reason as to why this happens? Or is Speedtest programmed to give fake results or something?
Try performing a factory reset on it and retest. Make sure to first capture all settings in the Admin utility for the Modem, especially if it's a combo Modem/Wi-Fi router unit. That might not be possible if it's a Stand-Alone Broadband modem, as some ISP's such as Spectrum-Charter do not allow home users to access their Modem. It's easier if you have separate Wi-Fi router or standard wired router that you connect to your PC, such as a Cisco/Linksys or Netgear.
