shimoly
Hello.
I have 3 users in my pc. I want to control their logon time. example: user1 6 hr perday. or user 1 login time 1pm - 6pm. How can i do this?
If I'm not mistaken, your ISP may have that option in Parental Controls, but it would have to be in the ISP's own browser, ie; AOL, MSN Premium, Earthlink, etc:
You may even try Link Removed, I know they have certain parental controls.
I do know for a fact that AOL has it in their Browser parental controls, which you can set time limits on the PC usage for each user and also set age limitations.
The link that patcooke provided is probably your best bet for today's PC usage.
Hope this helps
Don
patcooke
Microsoft MVP
Microsoft MVP
None that I'm aware of outside of large commercial network management systems.
Adamsappleone
U.S.Navy D.A.V.
Hope this helps
Don
