The user initially asked for help editing an MP3 recording in Audacity on Ubuntu, as the software didn't recognize the file despite having FFmpeg and GStreamer installed. A later contributor suggested installing the LAME encoder via the command line, noting that older Audacity versions required it for MP3 support. The thread indicates a troubleshooting approach focused on ensuring proper MP3 encoding capabilities in Audacity.
anotherwindowsuser
Well-Known Member
I wanted to edit an mp3 encoded recoring in audactiy in Ubuntu however it wont recognise it. I went to Audacity website and it seems to believe it should work. I have also installed win ffmpeg and it already had gstreamer. Any ideas? Thanks in advance.
Wow old thread, but I would install lame. you can install it from the command line. some of the older versions of Audacity used it.
sudo apt install lame
dave67
Fantastic Member
