The thread concerns a user’s difficulty finding the 'Details' tab in a contact within Microsoft Outlook, despite instructions to double-click the contact and select 'Details'. The responder explains that the user might be in the wrong view or interface, suggests troubleshooting steps like checking ribbon options, updating Office, or resetting view settings, and requests further details including a full screenshot and Outlook version for more precise help. Overall, the assistance aims to guide the user through common issues that prevent access to contact details, with a positive and helpful tone.
Dullstroom
The Help instructions say double click on contact then on 'Details'. However I don't find a 'details' option as per enclosed screenshot.
From your screenshot, it appears you are in the main contact form in Microsoft Outlook but not seeing the 'Details' tab as expected. Let's break down the process to ensure everything is done correctly and suggest a few troubleshooting steps.
Steps to Add a Birthday to an Outlook Contact​
  • Open the Contact:
  • Double-click the contact's name to open their full profile. It seems you have successfully done this.
  • Navigate to the 'Details' Tab:
  • At the top of the contact form, there should be various tabs like 'General', 'Details', 'Certificates', etc.
  • In your case, it appears the contact form only shows the 'Contact' tab and related fields.
    Troubleshooting Steps​
  • Check Ribbon for Tab Options:...
  • Open the Contact:
  • Sometimes, the 'Details' tab might be hidden or minimized. Look at the top ribbon to ensure all options are expanded.
  • Enable 'Details' View:
  • Navigate to the contact form and look for view settings or customization options to ensure that all tabs, including 'Details', are visible.
  • Update or Repair Office Installation:
  • If the 'Details' tab is missing, your Office installation might need repairs. You can do this via Control Panel > Programs > Programs and Features > Microsoft Office > Change > Repair.
  • Profile or Add-in Issues:
  • Sometimes, profiles or add-ins can cause UI elements to disappear. Try opening Outlook in Safe Mode:
     Press `Windows Key + R`, then type `outlook /safe` and press Enter.
    If those steps do not help, it might be useful to reset the contact form views which can sometimes fix displaying issues.
    Further Assistance​
    Would you please upload the full screenshot and verify which version of Outlook you are using? This will help us provide more tailored assistance. Each version of Outlook, like 2016, 2019, or Office 365, may have different steps for accessing these options. Feel free to reach out with additional queries!
