THHT
I am trying to create a Device Stage for my cell phone that is not supported. I only want basic features but would love free space and battery information if possible. I have followed tutorials and everything I can find from Microsoft as well as an old tutorial I found online but I am unable to get Windows 7 to recognize the code applies to the device. I am pasting my PackageInfo.xml as I am trying to just get a custom icon and name first before doing the entire Device Stage.
I have Windows 7 Ultimate 32-bit and it is in test mode. The phone is a Blackberry Storm2. If anyone can help, I would be forever grateful.
Also, once I package it and move it into the en-us folder, do I need to restart or perform any special tasks? Everything I read has said that after copying the file, I just plugin the device and it will read all the information but it never does. I also have changed the GUID in the CMD window each time but not in the packageinfo.xml as nothing I have read said to do so.
<?xml version=\"1.0\" encoding=\"utf-8\" ?>
<PackageInfo xmlns=\"[B]Link Removed due to 404 Error[/B]\">
 <MetadataKey>
  <HardwareIDList>
  <HardwareID>DOID:USB\VID_0FCA&amp;PID_8007&amp;REV_0210&amp;MI_01</HardwareID>
        <HardwareID>DOID:USB\VID_0FCA&amp;PID_8007&amp;MI_01</HardwareID>
  </HardwareIDList>
  <Locale default=\"false\">en-US</Locale>
  <LastModifiedDate>2010-10-28T13:37:00z</LastModifiedDate>
 </MetadataKey>
 <PackageStructure>
  <Metadata MetadataID=\"[B]Link Removed due to 404 Error[/B]>
 </PackageStructure>
 <Relationships>
  <ExperienceID>9056dda8-3dc4-40c1-a488-d10f7d1c6052</ExperienceID>
 </Relationships>
</PackageInfo>
It seems like you are attempting to create a custom Device Stage for your Blackberry Storm2 on Windows 7 Ultimate 32-bit. Device Stage allows you to interact with and manage devices connected to your computer. Here are some steps and tips to consider based on the information you provided:
Steps to Create a Custom Device Stage:​
  • PackageInfo.xml Configuration:
  • Ensure the PackageInfo.xml file is correctly configured with the necessary details.
  • Check the HardwareIDList section to verify that it matches your device's hardware ID.
  • Metadata and Package Structure:
  • Make sure the metadata entries are correct and correspond to the metadata files provided.
  • Check that the ExperienceID in the Relationships...
  • Check that the ExperienceID in the Relationships section is accurate.
  • Testing:
  • After modifying the PackageInfo.xml file and placing it in the en-us folder within the appropriate location, test the device connection.
  • Ensure the PackageInfo.xml file is saved in the correct format and encoding.
  • Restart and Plug-in Device:
  • It's advisable to restart your computer after making changes to system files like PackageInfo.xml.
  • Once you've restarted, plug in your Blackberry Storm2 to see if the custom Device Stage recognizes it.
    Tips for Troubleshooting:​
  • GUID Update:
  • While you mentioned changing the GUID in the CMD window, make sure that any GUIDs that are required in the XML files are also updated accordingly.
  • Verification:
  • Double-check the paths and locations where you are placing the files.
  • Ensure that the PackageInfo.xml file is in the correct directory structure within the en-us folder.
  • Permissions:
  • Check if you have the necessary permissions to make changes in the system directories.
  • Driver Installation:
  • Confirm that the necessary drivers for your Blackberry Storm2 are installed on your Windows 7 system. After ensuring these steps, try connecting your Blackberry Storm2 again to see if the custom Device Stage is detected. If the issue persists, you may need to review the XML configurations and troubleshooting steps. Let me know if you need further assistance or encounter any specific errors during this process!
