tom5674
When running the following script it will not display the results in a pop up window. This is only happening in Windows 7 Ent. The scrip does work fine from the cmd prompt. Some lines are commented out on purpose. Just want for the user to run this from the desktop and then tell me what the computer name is so I can connect to it remotely.
On Error Resume Next
Const wbemFlagReturnImmediately = &h10
Const wbemFlagForwardOnly = &h20
arrComputers = Array(".")
For Each strComputer In arrComputers
Set objWMIService = GetObject("winmgmts:\\" & strComputer & "\root\CIMV2")
Set colItems = objWMIService.ExecQuery("SELECT * FROM Win32_ComputerSystem", "WQL", _
wbemFlagReturnImmediately + wbemFlagForwardOnly)
For Each objItem In colItems
' WScript.Echo "Domain: " & objItem.Domain
' WScript.Echo "Manufacturer: " & objItem.Manufacturer
' WScript.Echo "Model: " & objItem.Model
' strBIOS=Join(objitem.Win_32Bios,".")
' WScript.Echo "SerialNumber: " & objItem.SerialNumber
WScript.Echo "Name: " & objItem.Name
' WScript.Echo "PrimaryOwnerName: " & objItem.PrimaryOwnerName
Next
Next
Set colItems = objWMIService.ExecQuery("SELECT * FROM Win32_NetworkAdapterConfiguration", "WQL", _
strIPAddress = Join(objItem.IPAddress, ",")
WScript.Echo "IPAddress: " & strIPAddress
Next
Function WMIDateStringToDate(dtmDate)
WScript.Echo dtm:
WMIDateStringToDate = CDate(Mid(dtmDate, 5, 2) & "/" & _
Mid(dtmDate, 7, 2) & "/" & Left(dtmDate, 4) _
& " " & Mid (dtmDate, 9, 2) & ":" & Mid(dtmDate, 11, 2) & ":" & Mid(dtmDate,13, 2))
End Function
Thanks in advance.
Tom
No, script did NOT run from command line.
Try this one:
'On Error Resume Next
    WScript.Echo "Name: " &...
Toulousaing
Try this one:
  Next
Next
    If isNull(objItem.IPAddress) Then
        Wscript.Echo "IPAddress: "
    Else
        Wscript.Echo "IPAddress: " & Join(objItem.IPAddress, ",")
    End If
  Next
Next
wscript.Quit
'Function WMIDateStringToDate(dtmDate)
'  WScript.Echo dtm:
'  WMIDateStringToDate = CDate(Mid(dtmDate, 5, 2) & "/" & _
'  Mid(dtmDate, 7, 2) & "/" & Left(dtmDate, 4) _
'  & " " & Mid (dtmDate, 9, 2) & ":" & Mid(dtmDate, 11, 2) & ":" & Mid(dtmDate,13, 2))
'End Function
My 2 € :
comment out the OERN during debug
there was a For.. missing
there was a Next missing
there was a test for IsNull missing
the WMIDateStringToDate function was not accepted
Best,
DTL
