Microsoft has published CVE-2026-62918 as a Microsoft Teams Spoofing Vulnerability, but the disclosure currently gives administrators far less to act on than its timing and product name suggest. The entry went live at 7:00 a.m. Pacific time on Thursday, August 6, 2026—five days before Microsoft’s next scheduled Patch Tuesday on August 11—without a corresponding Teams build number, KB article, affected-version range, exploit description, or customer mitigation notice. That leaves one immediately practical conclusion: do not treat CVE-2026-62918 as a Windows patch deployment task yet. Microsoft has identified a security issue involving Teams and classified its impact as spoofing, but it has not publicly supplied the information needed to determine whether the remedy is a Teams client update, a server-side service change, a tenant configuration adjustment, or a combination of those measures.
WindowsForum’s review of Microsoft’s Security Update Guide entry, Microsoft’s public CVRF documentation, and searches of the National Vulnerability Database and CVE Program record system found no independently published technical analysis, proof of concept, exploitation report, or additional vendor advisory for CVE-2026-62918 as of Thursday afternoon, August 6. The vulnerability exists as a Microsoft-issued CVE, but the operational facts around it remain largely undisclosed.
Microsoft Teams chat highlights possible impersonation alongside a security advisory and identity verification warning.Microsoft’s advisory establishes the category, not the attack path​
“Spoofing” is a Microsoft impact category, not a complete description of what an attacker can do. It generally means a security weakness could enable an attacker to impersonate a trusted identity, interface element, message origin, resource, or other signal that a user or administrator relies on when deciding whether to trust an interaction.
For a Teams vulnerability, that broad label covers materially different risks. A flaw could potentially affect how a caller or chat sender is represented, how a notification is rendered, how an external identity is distinguished from an internal one, or how a link, meeting invitation, shared item, tenant name, or other trusted-looking object appears to a user. Those scenarios have different remediation paths and different levels of urgency.
Microsoft has not said which of those possibilities applies to CVE-2026-62918. The company has also not publicly identified an attack vector, required attacker access, user-interaction requirement, privileges required, confidentiality or integrity impact, CVSS score, or whether it considers exploitation more or less likely.
The text accompanying the submitted advisory material describes Microsoft’s Exploit Code Maturity metric in general terms. That is explanatory boilerplate about how Microsoft communicates confidence in public exploit availability and technical detail; it is not evidence that working exploit code for CVE-2026-62918 is public. Administrators should be careful not to read that generic metric description as an exploitation warning.
This distinction matters because Teams is a cloud-connected collaboration product with a fast-moving service component. A CVE attached to Teams can be remediated in ways that do not resemble a monthly Windows cumulative update. Until Microsoft identifies the affected component and remediation state, a blanket instruction to “patch Teams” would be more ritual than response.
The missing build and KB number are the real limitation​
Microsoft security disclosures normally give enterprises enough data to map a vulnerability to products and updates. That may include a security update identifier, a fixed release, an affected product table, a severity rating, a CVSS vector, or guidance that the issue has already been mitigated in the service.
CVE-2026-62918 does not currently provide those operational anchors in publicly discoverable material. There is no named Windows update, no Microsoft 365 Apps update channel release, no New Teams version number, and no Classic Teams version number associated with the entry. There is also no published statement identifying Windows, macOS, Android, iOS, web, virtual desktop, or government-cloud scope.
That omission has a direct consequence for vulnerability-management teams. A scanner alert keyed only to the CVE cannot reliably tell an administrator which device inventory is exposed, because Microsoft has not published the software-version boundaries necessary to make that determination. Security teams should avoid closing or escalating a finding based solely on the presence of Teams.exe, the Teams Machine-Wide Installer, or an arbitrary client version.
The issue is particularly relevant for organizations that still maintain multiple Teams delivery methods. The current Teams client is serviced differently from the legacy Electron-based client, and many Microsoft 365 environments mix desktop clients with browser use, shared-device installations, virtual desktop infrastructure, and mobile access. A CVE record that says only “Microsoft Teams” is insufficient to establish that all of those paths are affected.
Microsoft’s public Security Update Guide is authoritative for the fact that it has assigned and published CVE-2026-62918. It is not, at this stage, an adequate remediation bulletin. The vendor needs to clarify three points: the affected Teams component, whether mitigation is already deployed across the service, and the action—if any—required from tenant administrators or endpoint-management teams.
Teams impersonation campaigns make the ambiguity harder to manage​
The absence of technical detail does not mean every suspicious Teams contact is an exploit of CVE-2026-62918. In fact, organizations should resist making that connection without evidence.
Teams has already become a frequent channel for ordinary social engineering: external users posing as help-desk personnel, fraudulent chat requests, malicious links, and requests to start Quick Assist or other remote-support sessions. Those attacks use legitimate platform features and deception; they do not require a Teams product vulnerability. The Cloud Security Alliance has documented recent Teams phishing and Quick Assist abuse, while Microsoft’s own Teams guidance warns users about external contacts attempting spam, phishing, or impersonation.
That existing abuse pattern changes the operational context of a newly disclosed Teams spoofing CVE. Users are accustomed to making rapid trust decisions inside chats and calls, often based on a display name, apparent organizational affiliation, warning banner, or familiar-looking request. If CVE-2026-62918 concerns the representation of any of those signals, its practical risk could be higher than a bare “spoofing” label conveys. But Microsoft has not said that it does.
Security teams should therefore keep two tracks separate:
  • Treat reports of fake internal IT staff, unexpected external chat requests, remote-access requests, and suspicious Teams links as phishing or impersonation incidents under existing response procedures.
  • Track CVE-2026-62918 as an unresolved product-security disclosure until Microsoft publishes the affected surface and a remedy.
Conflating the two would create false incident attribution. Ignoring the overlap entirely would miss the fact that Teams is already a high-trust user interface where impersonation defenses deserve scrutiny regardless of the CVE’s eventual technical details.
There is no basis yet for an emergency endpoint rollout​
With no Microsoft-issued KB or fixed client build tied to CVE-2026-62918, organizations should not rush an untested Teams installer into production and call the exposure resolved. Updating supported Teams clients remains sound hygiene, especially on shared workstations and VDI images, but it cannot be represented as a confirmed fix for this CVE until Microsoft says so.
The immediate administrative work is more modest and more defensible. Confirm that Teams clients are supported and updating normally; identify estates where legacy clients, disconnected VDI images, or frozen application packages prevent routine servicing; and preserve the ability to rapidly deploy a Teams update if Microsoft later assigns one.
Teams administrators should also review external-access policy with a clear business case in mind. Microsoft documents that allowing all external domains is the default organization-level posture for Teams federation, while allow lists can restrict external chat, calling, and meetings to approved organizations. Restricting federation will not “patch” CVE-2026-62918, and it may disrupt legitimate partner communication, but it can reduce the routine impersonation exposure that attackers already exploit through Teams.
For users, the message should remain concrete: an unsolicited Teams contact claiming to be IT support should be verified through the organization’s established support channel, not through the caller’s chosen chat or call. Requests to launch Quick Assist, approve an MFA prompt, disclose a verification code, install software, or authenticate to an unfamiliar page should trigger the same escalation process as suspicious email.
Microsoft needs to state whether customers must do anything​
The unusual part of CVE-2026-62918 is not that Microsoft issued a Teams spoofing CVE. It is that the company disclosed the identifier without publicly providing the minimum information enterprises need to assess scope or validate remediation.
There is no indication at present that the flaw is being exploited in the wild, and no public evidence connects it to the Teams phishing campaigns documented this year. There is also no basis to claim the issue has been fully mitigated by a Microsoft service-side change. Both claims would require details Microsoft has not provided.
For now, the vulnerability belongs on the watch list rather than the emergency change calendar. The next meaningful milestone is a revised Microsoft Security Update Guide entry that names affected Teams versions or confirms a service-side mitigation; until then, CVE-2026-62918 is a real Microsoft disclosure with an unresolved remediation path.
References​
  1. Primary source: MSRC
    Published: 2026-08-06T07:00:00-07:00
  2. Related coverage: msrc.microsoft.com
  3. Related coverage: nvd.nist.gov
  4. Related coverage: labs.cloudsecurityalliance.org
  5. Related coverage: cert.europa.eu
  6. Related coverage: cve.org
  7. Related coverage: cisa.gov
  8. Related coverage: cve.org
  9. Related coverage: cisa.gov
  10. Related coverage: github.com
  11. Related coverage: learn.microsoft.com
  12. Related coverage: github.com
  13. Related coverage: vulnerabilities.ncsc.nl
  14. Related coverage: microsoft.com
  15. Related coverage: microsoft.com
  16. Related coverage: vulnerabilities.ncsc.nl
  17. Related coverage: advisories.ncsc.nl
  18. Related coverage: linkedin.com
  19. Related coverage: techradar.com
  20. Related coverage: support.microsoft.com
  21. Related coverage: learn.microsoft.com
  22. Related coverage: labs.cloudsecurityalliance.org
  23. Related coverage: support.microsoft.com
  24. Related coverage: techcommunity.microsoft.com
  25. Related coverage: cdn-dynmedia-1.microsoft.com
  26. Related coverage: techradar.com
  27. Related coverage: windowscentral.com
  28. Related coverage: kiplinger.com
  29. Related coverage: tomsguide.com
  30. Related coverage: as.com
